My ati x850 XT has started acting odd. When running a 3d game the core temps will shoot all the way to ~110c and then locks the system. I have tried cleaning the card and applying new thermal grease (this helped a little as now it only hits ~98c). This card from day one has run hot (as in the entire card could give a second degree burn after only 5 minutes of bf2). I also have noticed a high pitched buzz (almost inaudible its so high). Could a part be dying and that's causing the core to heat up so fast and high?
BTW
older games (~3 years) don't seem to cause as much of a problem as bf2 and hl2 do (I can play eve-online for many hours with the cpu fan on full and have no problems but can't play hl2 for more than 5 minutes even at 100% fan speed).
I have a 480w thermaltake powersupply that is just over a year old and is clean inside so I know it has enough power.
Any help or suggestions are welcome.
Thanks.
BTW
Thanks.
