X850 Pro unlocking and speeds
Polarhound
I suck at [H]F
After running ATITool for the past couple of hours, I've stabilized my new X850 Pro at 570/597. I'm thinking about flashing the XT BIOS in, but everywhere I've read, people have been using much lower clock speeds with it.
Will flashing to the XT BIOS change what kinds of speeds I can go to? Will I be stuck closer to the XT's 540/540 due to temp control changes and pipeline increases? Is it worth it to make this switch?
First only the VIVO models can be unlocked on the Pro series. And if you do flash it to the XT Bios, it will run at XT Speeds. I dont think the Pros are good overclocker thoughs, and thats why people run lower speeds, because they cant run at XT speeds stabily. They just want the pipelines unlocked.
Mine is a VIVO. As for not being a good overclocker, I looped tests for 8 hours while I slept with no lockups and no artifacts visible upon observing the tail end.
IIRC, XT speeds are 540/540. The reason I asked about the side-effects is because people have mentioned BIOS swapping to cause changes in fan management and available top clock speeds.
needmorecarnitine said:
is flashing the BIOS the only way to unlock the extra pipelines?
There is a way to hard-connect them, but it has a very low success rate.
I have an x800 pro VIVO (I know... not quite the same thing...) that I've unlocked and am running at a little better than x850xt PE speeds. It's all about cooling and luck of the draw.
I get lock ups above 570 core and 595 ram, so I run it at 560/590 in games, but I'm on water and it rarely gets above 40 degrees C.
-dB
Using the xt bios won't help with your o/c, in fact thats a very good o/c for a pro. What brand is your card? If you have an agp card, and it's vivo using the xt bios will unlock the last 4pipes on the card, unfortunately when it does that it kills the cards fan control. The fan control section of the bios is located differently in the xt/xtpe bios' and they don't control the pro fan correctly. If you have a agp & vivo card, and want to unlock the extra pipes and keep fan control, post a screen shot of your fuse config from ati tool. If it's an unlockable card I can mod your pro bios to open the extra pipes.
It is an ATI Built AGP card part number 102A4751100. I'm looking in ATITool but I don't see a "fuse config" listing anywhere. I'm using 0.25b10.
Either upgrade to the latest version (.26b13) or hold down the control key while you click the settings button, it will then display extra info including the fields
CONFIG_SUBSTRATE_FUSES
CONFIG_ROM_FUSES
I need the exact data from those fields and usually a screenshot works best as a typo can be very bad.
CONFIG_ROM_FUSES
Ok, got it now. It was Ctrl-Shift and Settings. Here are all 4 new data points:
CONFIG_DIE_FUSES - 0xFFFFEFFF
CONFIG_SUBSTRATE_FUSES - 0xFFFFFF9E
CONFIG_ROM_FUSES - 0x861
GB_PIPE_SELECT - 0x6E48
Polarhound said:
I tired holding Ctrl down, but nothing different came up. When attempting to download b13, both links on their site are down.
Can you mail me a copy? ttfk@ttfk.com
And nothing different would come up either, because I'm an idiot and typed ctrl, when it should have been shift. Either way, I emailed you a copy of beta13 and the fuse config is show by default on that version.
EDIT: I see that you got it. Where there are E's in your two fuses configs, there need to be F's for the card to unlock. That means your stuck at 12pipes, sorry.
See my edited post above for the info you needed.
