GonzoP said:One of the great debates now is whether the 850pro is the better deal than the refrub'd x800xl. Its about $19 after 5% off. It certainly seems like the new x850pros will be stuck with just 12 pixel pipes. The other question is what kind of monitor you got? If you have an LCD and are not going higher than say 1280x1024 then you should be OK with that card. Your 3.1Ghz P4 is just right for either card as well.
