Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Is it worth buying some RAMsinks for my X800XT? It currently runs at 530/590 with no problems at all, and I'm wondering if giving my RAM some active cooling (92mm fan mounted 2" above the card) would help push it a bit higher...
I''ve found some Vantec copper ones, only problem I'm seeing is that its impossible to mount them on the front as the RAM is covered (but not cooled) by the GPU cooler :\
You could always dremel them down. I had to do that with an another card to get a water block to fit. The input/output prongs were directly above the chips.
