X800XT probs..
LionKinG88
Hello,
I just got my Connect3D X800Pro changed for a Club3D X800XT VIVO.
And i flashed my x800xt to xt pe. it worked perfectly, but then i oc pretty much, and i got blank screen didnt see anything and there was only power saving mode. I couldnt get back :confused:
So i had no choise so i flashed to normal x800xt bios, and it worked fine. But i wanted to have my card as a x800xt pe card so i tried another x800xt pe bios and it still showed me the same blank screen :(
Any1 knows how to fix this?
Thank You!
well first of all .. make sure you can actually o/c to xt pe speeds ... if you can't then flashing it won't help at all.
btw .. which bios are you using ? Is it an AGP bios or PCI-E bios ?
Hello, It worked fine on xt pe bios with normal xt pe speeds. Then i wanted to oc and i did too much then it fucked up.
And i got AGP bioses only!
I downloaded the bioses from here: http://www.techpowerup.com/bios/
And I used ATI X800 XT PE (AGP) 256 MB 520 / 560Samsung 1.6
and Sapphire X800 XT PE (AGP) 256 MB 520 / 560Samsung 1.6.
I got it working now, so the problem is solved.
I just removed all my drivers and overclocking programs and reinstalled the drivers and my XT PE bios started to work. :D
