x800xt pe for $419
BioPort
just wanted to let you all know that zipzoomfly has msi x800pro vivo cards for $419 with free 2-day shipping. i got one on monday, have successfully flashed it to to an xt pe, and its running rock solid.
its a kickass deal, and half-life 2 will love you for it.
an x800 pro for $419? heres a better deal an x800pro (nonvivo) for $388 free shipping
http://www.allstarshop.com/shop/product.asp?pid=9008&sid=UDSNG62DR20R9GTW56T124C0WXWQ2DA4
The title says x800xtpe for $419??
Soo far the best deal anywhere is this x800xt for $493 free shipping and just overclock it to PE speeds
http://www.allstarshop.com/shop/product.asp?pid=9705&sid=UDSNG62DR20R9GTW56T124C0WXWQ2DA4
actually newegg has the sapphire X800XT for $455. this is the link for it. its not in stock but when it is im probably gonna pick that one up if it's still $455, heh.
thats a great deal
Mikey20 said:
thats a great deal
i was like :eek: when i saw it for that low! but its a shame they dont have it in stock...im definetly going to try and get one when it is, though.
I purchased the blue sapphire x800xt from newegg and it is actually a platinum version:) With a simple overclock I have it above the default platinum speeds with no problem at all. Great card!
Gigabyte X800XTs seem to be the least expensive X800XT cards, but i've also heard that they don't overclock as well. nobody has them in stock either, but check back and they might.
http://www.gameve.com/gve/Store/ProductDetails.aspx?sku=VC-GIGA-030
http://www.allstarshop.com/shop/product.asp?pid=9813&sid=KQUQ3FJ4AKQ59H6MTND4JBRVLQ307PV6
http://www.allstarshop.com/shop/product.asp?pid=9814&sid=KQUQ3FJ4AKQ59H6MTND4JBRVLQ307PV6
the Sapphire X800XT cards seem to be performing well.
http://www.allstarshop.com/shop/product.asp?pid=9705&sid=KQUQ3FJ4AKQ59H6MTND4JBRVLQ307PV6
