Vengance_01
- Dec 23, 2001
its normally 349$, but two 50$ instants, make it 249. GRab them while you can.
[H]ellbringer said:Just got out of prison so -
Where is this card on the ladder as far as performance?
I know it's not the bestest and greatest right now...
Second? Third? etc.
Thanks.
dragontales said:It is slightly behind the 6800gt. So it's a pretty juiced up card at a lower price compared to Nvidia.
annaconda said:Too Expensive from MY Point of View.
jarman said:
Slider19 said:How much of a jump would it be from a 9800pro?
Dosomo said:It depends on the rest of the system. If the rest of the system is fast enough, then the X800 XL will be a huge step up from the 9800 Pro in actual real gaming. The benchmark scores will increase too of course, but the real world gaming difference will be huge. Games that the 9800 Pro can only run at 1024 X 768 with 2X AA, the X800 XL will be able to run at 1600 X 1200 with 4X AA. This is a real visual difference you can see.
You just have to make sure the rest of the system can take advantage of a X800 XL.
I disagree completely.Oh4Sh0 said:Probably not an extremely significant difference.. a bit higher frame rates, but that's all. don't expect wonders![]()
Agreed. The X800XL is twice as fast as a 9800 in many instances.Apallohadas said:I disagree completely.
I went from a 9800pro to an x800pro and that was a huge leap in performance and quality.
Jason711 said:2k1 is more of a system bench right now than anything... would be better to use one of the more gpu dependant benches.
Jason711 said:2k3/2k5 .. perhaps aquamark.![]()
