T-nm said:Sapphire....![]()
skratch said:U have no clue
You need to see if your card has the lazer cuts on the chip.If they are there it wont mod to 16 pipes.You might be able to connect the bridge like we used to on the amd chips.
to the dumbass that posted the eyes the sapphires are the only cards that mod 100% and work.
They were all modding so sapphire is now lazer burning the chips not to mod.
Digital Viper-X- said::O My BBATI modded just fine with a bios flash =p
BTW check if you have 1.6NS ram
if you do, even if it doesnt unlock you can oc that ram =D
far-cry said:Is there way to unlock all 16 pipelines without hardmod?
