matt00926 said:The heatsink could not be making correct contact with the core. Either try to take apart and reseat the cooler or get a new cooling device. You might also want to blow the dust out of the fan with compressed air and make sure the fan is spinning at a proper rate while in use.
UT-Jackal said:Thanks a lot guys, i'll look into an aftermarket cooler. Any recommendations?
Altron3k said:i have a x800pro agp card, and i use the Zalman vf700ALCU cooler, it works great! My card is OC'ed to 573core/546mem and my card never goes above 55C at max load (artifact testing). While playing games, i noticed that it never gets even close to 50C. The all copper version is cheap nowadays, i would suggest that, plus, compatible with a wide range of cards.
