X800Pro, A64 2800+??? Good?
bobsaget
I think that I need to upgrade to 64bit and the x800Pro.
Is the 2800+ A64 and x800Pro a good pair?
thanks
Sounds pretty good to me. But if you have the extra 20 bucks or so try to get the 3000+, they 2800+'s are usually speed binned 3000's so not much OCing headroom.
oh i see... forgot about that ^^^
yeah, I probably will get the 3000+ A64.
I have heard that the difference between the A64 3000+ and the 3200+ are not worth the extra 60-80 bucks... is it?
thanks for the input!
