X800gto2 --> x850xt pe question
exoticalex
Hey guys, My x800gto2 should be arriving from newegg in a few days, and I have a quick question. I am going to unlock the pipes, but am I safe to use the stock cooling if I overclock it to x850 speeds???
Thanks!
You might be alright, but the card will run hotter than what I would be comfortable with.
Plus, the fan will likely run close to full speed far too often.
I would defiantly purchase an after-market cooling solution.
one of mine did with the stock cooler. it wouldnt do xt-pe without a aftermarket cooler. i still have a arctic cooler for one if you need. id sell it pretty cheap say $30 shipped (used for 1 week than went water)
I am running a coolance PC3 system, and I was planning on cooling the CPU and the northbridge. I have the GPU cooler as well, but I think cooling all 3 would overload the radiator. Should I forget about the Northbridge, and cool the GPU instead?
I plan on doing some minor overclocking...
Thanks!
By the way, I am trying to get the best performance, without making the system too loud. My prevous setup was simply too loud!
I just finished unlocking and overclocking my x800gto2, also from newegg. I left the stock heatsink on to see how well it would do. I have it unlocked/overclocked to 530MHz core and 580MHz memory. Idles around 40C with fan speed of 54%. Running ATiTool gets the temperature up to 69C and a fan speed of 93%. ATiTool is nice since it allows for fan speed changes according to temperature. IMO, anything above 65% is noticeable to loud. Not too big of a deal since that only happens when playing games. Granted my ambient temp is quite low since it's winter here so I plan on taking off the heatsink and applying AS5. Hopefully that will bring the temps low enough once summer comes around. The card could do XT PE speeds but I wouldn't feel comfortable leaving it there without a different cooler.
Anyone know what kind of results I can expect replacing the thermal interface? More than a couple degrees?
from what i read here "nobody runs 3dmark anymore" so why would you want to overclock your card? the couple percent benefit you get will only produce artifacts in games, make your card die quicker, cause rma's etc. dont put arctic cooler on it either. that cheap piece of crap has cracked many cores. put as5 on if you think it will help, but it will invalidate many(not all, i know) warranties. i have been doing this for many years. i have no reason to give you bum info. dont bother. it will mostly just cost you grief. overclock something cheaper with more performance bennies. buy a 3000 venice or 144 opteron or something.
what the heck are you talking about?
i dont oc to gain points in benchies... i oc to gain performance in the games i play
why not?... why overclock anything?
the connect 3d x800gto and sapphire x800gto2 are some of the best bang-for-your-buck overclocking/unlocking cards out there
thats a risk you run oc'ing, but sometimes the benefits outweigh the cost.... but if you cant afford to replace the component then dont oc it
more than likely reapplying the TIM will help, and yes it may void your warrantee, but so will overclocking it... again if you cant afford to replace the component then dont do things thatll void the warrantee
dont bother. overclock something cheaper with more performance bennies. buy a 3000 venice or 144 opteron or something.
again why not... thats why people come to these forums...
you can get a gto2 for around $200 and would gain more performance by oc'ing the video card than buying one of those processors and oc'ing it
besides if you overclock your processor wouldnt you:
the couple percent benefit you get will only produce artifacts in games, make your cpu die quicker, cause rma's etc.
:rolleyes:
ontopic: to the OP.... overclock as far as the stock cooling will get you without getting too hot or causing artifacts, but more than likely youll achieve a higher oc and cooler temps with aftermarket cooling... the zalman vf-700 and arctic cooling are good choices
I think you are looking for cause, not cost.
Also, you can get MUCH better performance in games from overclocking, and in fact, most games benefit significantly more from a faster GPU than a faster CPU.
And as pstang put it, any argument you can make against overclocking a GPU can be exactly made against overclocking a CPU, which you somehow seem to favor.
Also, it is not a couple of percent. Try 25-40% by unlocking and overclocking. I got my Connect3D X800gto for $150 AR, and it unlocked to the full 16 pipes, and overclocks to 540/540 without any artifacts at all, all on the stock cooler. While this isn't true x800xt pe speeds, its pretty darn close, and for less than half the cost. Bang for buck anyone?
check this out
http://www.hardforum.com/showpost.php?p=1027953890&postcount=2352
you will see that i am number 14, the second highest gt sli, higher score than 90% ot the gtx sli. this is non oc. so i guess if i like overclock my video cards and get that 40% boost,
i could be scoring damn near 20k. i guess.
i'm just kidding. flash that bios. turn it up. buy that aftermarket cooling. i am sure you will be glad that you did.
check this out
since when are the stock clocks on a 7800gt 513 core/1197 mem?
you evidently dont know anything about the x800gto2... its got a r480 core(same as the x850) that has 12 pipes, but only because of the bios not because it is a bad core.... all it takes to get the 16 pipes is to flash the bios, and if you oc it to xt-pe speeds or beyond... as long as it doesnt get too hot or have artifacts i still dont see a problem
besides, where are all the threads of x800gto's/gto2's failing because of overclocking and unlocking?
but evidently you are too busy playing 3dmark03/05 all day to know these things
i run stock cooling also on mine and I have it running at 575/575 ive ran it as high as 605/610 but it gets mighty hot, it never artifacted though(I got 7200 in 3dmark yay me ?).
idle i sit at roughly 42 and load is right around 70c, I have a thermalright v1-ultra in the mail though hoping to drop that load temp down to mid 50's
It has been proven time and time again that cpu's are not the limiting factor for performance in many many games.
My x800gto2 -> x850xt-pe means bf2 is playable at 1600x1200 instead of 1024x768,
although, of course, BF2 sucks.
Dude.. Ragtroll is my favorite game.. sure, it's a little repetitive.. but, hey.. It looks good, and I can do it at 150FPS
the stock clocks on my evga gts are 470/1200. the 513 core reported is taken from another one of the core engines that runs about 45mhz faster. but evidently you wouldnt know this because you are busy calculating your 40 to 50% increases by some way other than 3dmark, and also busy incesssantly bickering over minutiea.
i never advised the op to not flash. i merely told him that in my opinion the benefits to be gained from overclocking his card would not be significant in the long run.
and i agree with you. there are no threads anywhere on this forum from people having trouble/rma'ing their cards because of overclcocking. this is also why the majority of manufacturers will void your warranty if you overclock, use aftermarket cooling, etc. they just do that for the hell of it.
to op. i offered you an opinion. i didnt demand that you do what i opined and bombard you with arcane facts and figures. you can either do that thing or not do that thing . good luck in your endeavors. i didnt mean to get anyone's panties in an uproar. apparently, you must overclock that card or you are stupid, dont know what you are talking about or you are busy running benchmarks.
Because the place I ordered it from didn't have the VIVO cards, and the VIVO cards they sell are about $40 cheaper... but mine clocks great... so I am not complaining, I don't use VIVO.
Your opinion in no way answered his question. His question was whether he was safe on stock cooling overclocking his card. Not 'Can I have your opinions on whether or not I should overclock my graphics card, and why?'
Whether you just felt like being an ass or what I really don't know, nor do I know what you posting your 3dmark benchmarks have to do with him overclocking his card on his stock video cooler. :rolleyes: It was obvious from your first sentence that you just wanted to be obnoxious...
Anyhoo.. op, I haven't heard of gto2's artifacting or dying from excessive heat, so just take your time, oc a small amount at first, check your temps... and see if the loudness of the fan is acceptable to you before you decide what to do. Nobody here's going to be able to tell you exactly how your card will perform and/or how hot it will run.
