Can you volt mod this card by the bios, i just went ATI and i kinda dont know squat. Cause my oc is terriable but my temps are like 38c idle and 45c load.
I see you've unlocked your x800gto to 16 pixel piplines. How well does it overclock? My unlocked x800gto does 500/590 but crashes at 5mhz higher on either core or memory. Also, how are your temps? I get 64 degrees C load.
Mine right now is at my sig. Im still testing around with prime95 to see exactly what is crashing... But if i try to do 570 on the core it crashes, which is why i need more volts, cause it doesnt even atrifact. But my memory atrifacts at around 1125. And i have a silencer and havent seen temps over 51c
