Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Yup, I think the temp is OK to your Vid card. Do you use stock HSF or watercooling?
Despite of 39 Celcius on idle (room temp was about 23 Celcius), my GPU is even hotter at load (~ 70 Celcius) on benchmarking 3DMark2005 (stock HSF). I am planning to go back on watercooling for my vid.
My XT PE would get to about 78-80C at load on the stock X800 Pro cooling (flashed card ). Even those temps are fine (anythign up to about 100C) is, but lower is always better of course. 59C is a great temp.
