x800 xt PE loosing power?
silvscorp
I did a search but can't find the exactly problems that I am experiencing.
I got a x800 xt pe from ebay, long story short. The seller RMA it to ATI and now I got a brand new card. Installed it with the latest CATALYST dled from ATI last night. Everything is in default setting, not OCed and the Overdrive is not checked. However, the problem is that some times my screen just goes black, like loosing signal from video for about 1 second and it turns back to normal again. This happens both in games and just on regular desktops. Anyone experienced this before or has a possible explaination as what might have caused this?
The power connector to video card is shared using an extantion connector with harddrive.
Power supply is Seasonic s12, brand new as well (power outout in each rail appears to be normal). Video card is connected to the dell 2405fpw through DVI. In bios, the agp voltage was set to 1.6v. I have turned off the AGP fast write and lowered agp volt to 1.5v, so far I haven't seem the problem come up yet but it was only used for about 15 minutes. I'll try again later today see what happens. In the mean time please share some of your thoughts.
btw, anyone can point me a good site for some optimal configuration on the CATALYST? This is my first ATI card, I've been using nvidia for years.
I have a 6200TC in a Socket T computer that does the monitor flicker once in awhile as well. Too lazy to trouble shoot it as i dont really use the computer. Just thought i'd mention that its problably not a hardware problem.
Catalysts basically install with optimal configuration unless you want to customize such as enabling T-AA. I'v been using them for a few years now and i havent had to touch the default settings to improve game performance.
If the problem presists, i have to ask if you either used Driver Cleaner to remove all eliments of Nvidia Forceware off your computer prior to installing Cats, and/or did you do a fresh format?
I have the same card and a PP&C 480 watt PS. I have the Dell 21 inch flat sceen and the screen has gone blank 3 times just writing this reply. I am running in digital mode and recently upgraded to the latest drivers. I was thinking, I might connect via the analog cable to see it the problems go away. But if they do, then what, I didn't buy this setup to go analog.
looks like we are having the similar problem, same card, same branded moniotor via DVI. Did you just installed the driver (which version) recently or you started to experience this long time ago?
I haven't find a pattern as of yet. I just installed the card last night so within 2 and half hours, it gone blank 3 times. I'll go play around with the setting more and see if I can pinpoint the problem.
Anyone's got a good guide or link for how to setup the parameters in CCC?
Did you guys manually setup the AA and AF or use the "let application control"
Should I disable the PCI read and write under the SMARTGEAR?
thanks,
This happened to me with my current setup but I was overclocking as hell and I think it was due to my power supply. Since you have a PCP&C, I guess the problems is elsewhere.
Para
sounds like the monitor is adjusting or like your card is adjusting something. sort of like when you install a new driver, there is a period where the screen goes black, thats what it sounds like.
But who am I?
Ok, I think I fixed the problem. I changed my memory timing from 2 to 2.5 and also disabled that self recovery thing in the CCC. I think that goes to blank thing is mainly caused by the self recovery. 3 Hours so far and no blank screen yet.
Try changing back your timing back to 2. I always turn off VPU recovery and all those stupid things cause they usually cause problems.
yea I think that vpu autp protect is what's causing the problem. I might leave the memory at 2.5 cas cuz I want to get a stable OCed graphic card.
I use the ati tray tool to OC but some how it won't load the profile on start up. Is there a way or that's just how it is? Or what other good OC program that can auto load the setting at start up?
thanks
