Im building a new PC with liquid cooling and im getting a X800 XT. I need to know if the Danger Den MAZE4GPU water block will fit (using the brackets).
The x800 has the same mounting setup as the 9800 series cards from ati... so that means that if the dd block would fit on a 9800 series card it will fit on the x800. Here is the link to the graphics block on their site : http://www.dangerden.com/mall/Blocks/maze4gpu.asp It looks as though it will fit on the 9800 series card. if you have doubts I would e-mail DD so that you dont have problems with the block.
