Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
is it normal for the temp of my x800 pro to jump up 7 or 8 degrees celcious as soon as i open the 3d view in ati tool....ie: it sits at 47deg c and goes to 53 deg c 1 sec after 3d view is open....temp updates are every second on ati tool.
