X800 Pro temp sensor?
Dillusion
I think it has one, right? If so, where can i monitor it, i cant find it in the ATi display properties advanced tab thingy.
thanks
thanks
It should be in the OVERDRIVE tab (I heard it wasn't very accurate though).
Maybe, dl'ing ATI Tool might be a better way to observe temperatures.
i dont have an overdrive tab, im using the 4.12 betas, should i go back to the 4.1's ?
I don't either, just go download ATI Tool. It will monitor the temperatures for you.
lol.. I had the overdrive tab in my 4.11 officials. Uninstalled them, used driver cleaner in safe mode etc, then installed the 4.12 betas and now it's gone (overdrive) and so is my gun on HL2 when I hold it over water :eek:
