I got a good deal on an Asus X800 Pro Vivo so i bought it and it arrived today. this is the first time i have used an X800 series car, but i have had 4 6800 series cards. Here are some questions i have
Do X800s have build in temp monitors like the 6800s? I didnt see it in the display properties....
What should i be getting in 30d3 and 3d05 with an A64 3000+ with cpu and video at stock speeds?
Which drivers are the best to use? i have the 5.10s installed without the catalyst right now.
The card i had directly before this card was a PNY 6800nu.... so far in CS:S the X800 pro seems to lag a bit more than the 6800nu but perhaps i need to tweak things a bit....
As soon as i get the aftermarket cooler on this im going to see if it will do XT PE speeds and then attempt the bios flash to XT PE.
