X800 Pro help
TheBruce
Ok first of all, I'm curious about my drivers. I installed the newest 4.12 Catalyst drivers(or so I think), yet when I got to my display>advanced properties it talks about some 6.14.(something) stuff. Is it supposed to say that? Also, are the Omega drivers better?
Another question, since i have a VIVO i know that I can unlock the extra 4 pipelines, and I want to know if its A. worth the risk, if B. my 300W power supply can take it, and C. if it will make my cards life shorter(how much shorter?)
thanks alot guys
usually look at the very end of the number to see if 4.12 is there. and yes the Omega drivers are good. I used them when I had my 9800pro. I would reccommend a bigger PSU. 300w might be ok but bigger is better :). I would go with at least a 400w but thats my oppinion
