Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
just got my x800 today and i was wondering what speeds i should run it at and also.. what drivers i should use. im new to ATI too current speeds. are core: 472.50/mem: 445.50 temp is 41*C on air. also what is overdriver should i have it enabled?
lol, that help me was comical. Anyway that card should easily hit 500 mhz. I wouldnt bother with overdrive. It just does the OC for you but usually only bumps you up by like 5 mhz. A little silly. I use rad clocker or ATI tool to adjust clocks....Good luck and report what you got!
I'd suggest the 4.7 Cats or the 4.9 Betas, either work great. I'm using the 4.9's. Overclock the hell out of hte x800! I want to volt mod mine (pencil trick) and see if I can get to at least 580MHz on the core. or 600 on the memory. Should be fun. Good luck.
