x800 only 8k in 3dmark03
Azn226
is my system bottlenecking sumwhere? cause its really bugging me. i have Kingston hyper x pc-4000 its at 1:1 and the timings are 3-4-4-8. is they anything i can do? cause i know the x800pro supose to get 10k in 3dmarks03
is that an nf2 mobo? You will get better performance with the last ram timing at 11. That won't help too much though. Do you have the latest mobo drivers?
I would think it is your processor, since the 3000+s don't fully utilize the x800's power, and even with the overclock you don't have all that much cache.
yes the mobo is a nforce2 and i have all the latest drivers for it.
and for games it runs pretty damn nice at MAx settings
Is this a general rule that's true of all nforce 2 mobos? Set the last ram timing at 11?
Yes. Every nf2 mobo i have tried got better results with that setting at 11. Albeit, it wasn't much more, but it was there. Maybe 50-100 points in 3dmark01.
Make sure you have cats 4.6 as there is a good boost in 3Dmark with those.
I got somewhere at 8300 with the X800 Pro using cd drivers, then with 4.6 it was 8900.
After clocking it to 540/570, I get 10395.
What's this thing about setting a timing to 11 on NF2 boards?
Barton 2500+ (185*11.5) 2127mhz
Asus A7N8X Rev 2.0 1005bios
2x512mb Geil DDR3200 6-3-3-2 Dual
Thermalright slk-800-u heatsink
Antec True 430watt
X800PRO Vistiontek 540/570 3Dmark03 10395
Compro Videomate TV/FM Gold Plus
Maxtor IDE pci card, Audigy 1
HDs WD, 3x80gig, 60gig, 30gig
http://www.toonguru.com/
to bad the pros dont have the 16 pipes like the XT's hehe 540 overclock is pretty nice
I just cut it there to be safe. I ran 3Dmark once at 560/560 and nothing went wrong. The way my card is going I don't see 560/580 being a problem. I stopped ATI Tool while it was searching for max core once it was going past 564, even if it could go further, without some better cooling I just don't want to stress it too much. And the benfit starts to be less as you go further.
what catalyst drivers are you using? 4.6 gives a huge boost in performance, i break 12,000+ points OCed
I get 10,647 with comp in sig with the x800 pro at 540/1ghz with the 4.7 beta cats. Not the highest it goes either. Stock is like 8500 for the x800. Yours sounds about right though. I'm on a t-bred too 2600+. 4.7 betas suck right now. Wait for the final release. I had a lot of problems, like glitches and stuff with them (not with 3dmark and some games, just desktop bugs adn what not). Back on 4.5's which don't give me overdrive. Anyway, it's all about the GPU o/c :D Here is link http://service.futuremark.com/compare?2k3=2677595
I got about 9k stock on a Pentium 4 3.0C. After OC'ing the video card and the CPU as shown in the sig, I get about 13k.
The key here is dependent upon your fsb setting.
fsb < 200 - set to 9
fsb = 200 - set to 10
fsb > 200 - set to 11
ya its your cpu thats holding ya back cuz Im running a 9800pro and get 7k on 3dmark03
Yeah, the Ram is also holding you back.
Really you don't want PC4000. A lot of times the timings are not adjustable (you might be stuck at 3-4-4-8). A better and cheaper choice might have been a 2-2-3-6 (or lower) PC3200 and overclock it.
cause i had a intel setup and i didn't have enough money to buy pc-3200 ram. thats why there's pc-4000 in my setup right now. but later on im getting a 1gb of pc-3200 :)
