X800 blue screen issues
Dafinga
This has been an ongoing issue for months ...
I tweaked many issues and now blue screens only occur on specific games. I used to blue screen on COD:UO, but solved that with a multiple Network card issue ... yada yada.
Now what happens is on BF2 and Dawn of War ... about 1/2 hour to 1 hour into game I blue screen. Than randomly 10 - 20 mins in between. It only happens with high these games. I have patched DOW with the appropriate patches and of course BF2 is new.
The drivers I use for my video card are the latest Omega drivers and I still had the issues with the standard ATI drivers.
If anyone could help, it would be very appreciative. My guess is that its a power issue or heat issue, though i have been keeping teh sides off the case with the air conditioner going, so maybe its more of a power issue. Let me know what you think. My specs are found below.
Also I was thinking, maybe its a voltage issue to my video card. I will be researching how much voltage my card needs, but if you guys know ... cheers!
Thanks
Here are my specs:
MOBO: ASUS A7N8X-E Deluxe /w onboard Soundstorm audio
CPU: AMD 3200+ barton @2.0ghz - Thermalright SI-97 heatsink
RAM: Crucial Ballistix 2x512mb 3200 ram/dual channel
PSU: Vantec Stealth 520Watt Aluminum Power Supply
VC: ATI X800 pro 256mb
HDD boot drive: WD Raptor 36.7 GB
HDD Slave drives: WD IDE 120 GB 7200rpm & WD SATA 200 GB 7200 rpm
DVD Drive: Plextor DVD Burner Model PX-712A
FANS: 4x 80mm fans ANTEC
