X79 and ECC
TurK-FX
Did anyone try ECC memory on X79? I currently have regular memory, but I wantt o swap the CPU to Xeon and add 64gb ECC memory. I found 64gb ECC ram for $160. My question is anyone tried it with Gigabyte X79 ud5? Actually asus x79 has it in QVL, but gigabyte dont have it in the QVL.
Unbuffered ECC works fine on X79, also most of the desirable 16xx E5s are unlocked. Memory support is mostly determined by the cpu IMC, as long as your motherboard is not retarded by getting in the way somehow. I only ever bothered to get 8GB modules, crucial and kingston no problems.
No idea on Registered ECC on X79, you're on your own there.
I have used rimms with X99 and they work great. Not tried any load reduced (pricey and slower) but no problems populated with 32GB in every slot, 256GB. Only C612 boards are built with 12 slots per socket, but wouldn't surprise me if this is just marketing as I've yet to find an actual difference between X99 and C612 (neither can your OS). Sadly, only 16xx E5 v3 can be found unlocked and the good models never became available even though they got part numbers, by the time v4 came out we were totally screwed. There is an also interesting hack of sorts for any v3 to full turbo boost every core by running early bios code. Cheap 18-22 core v4s showed up on ebay though so I still make a nice system out of one.
Don't worry, intel finished fully fucking us workstation builders over with X299 and Xeon-W segmentation but Threadripper happened so fuck them right back.
Himm. The ram I ordered was registered. I read somewhere someone got it working with Asrock X79 Extreme 11. I got a E5-1650v2 which supports ECC.
