Joe: Why let it die? We're taling, if you don't wanna take part, dont.
Dan, yeah i see what yer saying about a new OS... i thought bout that "its new, gotta get used to it"... im having some compatibility issues, same issues ive had with Vista... regarding VNC. I use VNC because its a big preference of mine. But it doesnt seem to work properly with 7... i have vista x64 issues, and now use logmein, but now im having same issues with W7... it lets me login, but then doesnt accept my password.
I tried using it at lunch, and said "ugh i miss XP"
They'll eventually update VNC so that it works with Windows 7. Give it time. The OS hasn't even been released yet. I would just use RDP in the mean time provided the client machine supports it. It is one thing to adopt a new OS for gaming and general desktop use. It is quite another to do so for work related tasks. If you depend on the machine for productivity you should do extensive testing with your applications before making the switch. Sometimes that means you have to hold onto an older OS longer than you'd like. If you really want the new OS sometimes you have to create work arounds like I did. I've got a couple of applications I use for work that I've never been able to make with work with Windows Vista 32bit, x64 or Windows 7 x64. I also have a device that I need for capturing BIOS screen shots from the S-Video out on the video card of my test systems. I can't get it to work in Vista or Windows 7. So I keep an XP box around for those tasks. I'd love to eliminate that machine and use my Windows 2008 R2 server, or use Windows 7 for that machine but I can't just yet.
