X58 NB temp safeness?
wildzcardz
I have a EVGA x58 Micro SLI... was wondering what are safe temps for the NB on the x58 chipsets?
anything under 70C though you really shouldnt see anything over 60C unless it has the NF200 chipset along with the x58 chipset under the same heatsink.. if the temps look high to you.. just get a cheapo fan that's the same or similar size to the heatsink then take some silicon and glue the fan to the heatsink.. all ya gotta do is twist it off if you decide you dont like it there or its not helping..
You could get something like an Antec Spotcool to cool your MB. I'd heard people using it on their Rampage II Gene motherboards (identical to your EVGA X58 Micro SLI).
http://www.overclockersclub.com/reviews/spotcool/
I have Gene myself as well as the Spotcool and it has lowered my NB temps by at least a few C, this is at stock, no overclocking.
Thanks for the link. I've been searching for NB coolers..
