X58 board with standard WC?
rgMekanic
[H]ard|News
Just curious if there was ever an X58 board made with a waterblock pre-installed, ala the Asus Formula viii and the like.
I'm still on X58, and plan to be for the foreseeable future as there hasn't been any massive performance gains to be made in the last few years.
Currently on a Big Bang XPower, but its showing its age a bit, building a new loop in a new case, so it got me thinking.
Thanks!
~Rich
I mean, the XPower was (if I recall correctly) one of the better X58 boards... it's an old platform, any board you find is likely to be showing its age by now. Unless you mean some kind of electrical issue? People also seem to have a very high opinion of them, $200+ for higher end boards after a quick glance on eBay. I'd personally have a really hard time sinking that kind of money in to a dead platform.
+1 no sense in buying new parts when you have one of the better motherboards to begin. Lot of other parts would make more sense.
I'm sure you could find a used chipset water block for that board. I'm not sure if there were any x58 boards that came with blocks, my old Foxconn Blackops did, but that was a x48 chipset.
No massive performance gains?
The memory controller is massively faster on the newer setups.
The IPC is a lot higher on the newer setups.
x58 is still a good platform for some things.. but saying that there have been no massive performance increases is just silly.
OP, list full system specs. An SSD, hexacore, or new gpu/monitor would benefit you more than a motherboard of the same gen.
Yeah, not dropping $200 on a board this old. I'd do a full build at that point
MSI Big Bang Xpower
Xeon W3690 @ 3.8
12gb Mushkin Silverline 1600
OCZ Vertex 460 SSD
WD Black 1tb storage (old as hell, finally starting to fill it up here and there heh)
R9 280x's in Xfire, but just ordered a Nitro Fury today
Xion 1000w PSU (want to upgrade this soonish)
RIght now all stuffed in an old Koolance PC2-650BK case I bought 12 years ago hah. But I recently bought a 900d and have been getting the things to build a new loop and move it over in the next couple weeks.
Samsung PX2370 23" 1080 monitor
I get what you're saying, and single core performance is up a lot. But I remember the MASSIVE jumps from pentium 4, to Core 2, and beyond, where every year or 2 we were seeing 2-300% gains. I guess I've just been waiting on another leap to come. Which it has, but right now only in the uber expensive server market
Just a quick add, I know it isn't anywhere near a complete comparison but..
PassMark - CPU Performance Comparison
$800 build for 20% overall, meh.
The performance wouldn't come from IPC improvements (though you would also be able to push a substantially higher OC) so much as interface improvements. PCIe 3.0, much faster RAM, native USB 3.0, faster SATA and PCIe based interfaces for SSDs...
From a gaming perspective your best upgrade is a higher end GPU, though - I'd never recommend spending money putting a 280x under water.
The RAM and PCIe 3 would be nice, my mobo already has USB 3 and SATA 6gb, I just ordered a Sapphire Nitro Fury that should be here Thursday, bummer is no one makes a full cover block for it
