- Nov 14, 2004
Yeah, I've seen a couple of those builds with the gpu upgrade and atx psu... couldn't see if the external psu was providing just pcie 12v or atx12v as well.
So the way the power gets regulated properly from the PSU to the CPU happens in a couple stages:
- The MOSFETs (1 per phase) step down the DC current from the PSU from whatever the input is (usually 12VDC) down to 5VDC
- The VRM module steps that 5VDC down to whatever is directed by the CPU (based upon throttling, load, etc)
In the case of the ASRock Z77E-ITX, the MOSFETs (ON Semiconductor NCP5369 chips) have a Voltage(in) acceptable range that extends up to 25VDC for normal usage and 30VDC for peaks/surges.
So... I just plugged it right up. As an additional safety measure, I added copper heatsinks to the power regulation circuitry on the power board and upgraded the fan; temps are nice and low.
Current issue is booting with the GTX670-4GB installed, so I'm working that out; there should be plenty of power as the system only pulled ~285W from the wall with the ST45SF-G.
cool, man. are you replacing the cpu hsf with a bigger one or just giving the same one more room to breathe?
Incidentally, the pcie-power cable that comes with the x51 has custom low-profile 90-degree 6-pin connectors... i would love to find a source for these (and their 8-pin variants)!
