- Jun 3, 2003
I put my computer to sleep, and it sleeps just fine. I turn it back on, and it stays on for about four seconds, and then turns off. Two seconds later, it comes back on for four seconds, then turns off. It will loop doing this infinitely until I hold down the power button or cut the power manually.
This wouldn't be half so annoying if I could at least enable hibernation.
Specs are in sig. Chipset drivers have been installed. Ideas?
