X4 925 voltage locked....help!
GMcDougal
i recently upgraded from a 7750 be to a 925. for some reason the voltage is locked, if i change it about the stock 1.25 in the bios is bumps it down to 1.20. the slider in amd overdrive is maxed out too at 1.25. i had no problems upping the voltage on my 7750 be. my motherboard is an asus m4a78e and this cpu is on the supported list. i also tried reflashing my bios and still did not help. thanks!
think i may have figured it out..i read that an asus technician has stated that with some cpu's overdrive and cpu-z will show the incorrect voltage. cpuz and amd overdrive say 1.25 but asus pc probe says my vcore is at 1.37. in amd overdrive under the cpu extra OV slider it is at 0.100. i didnt put that there so maybe thats how i have to adjust the voltage is using that slider. it must be working that way because i just upped my fsb to 229 and prime 95 has been going for over an hour, no problems. ill keep everyone posted on more findings.
