X25-M as a primary drive
Rosewood
I couldn't take it any longer, I had to have an X25-M as my primary drive in my new rig.
I've read all the reviews and the life expectancy numbers don't bother me, but I will be damned if there isn't a little nagging voice in the back of my head.
I'm trying to think of things that I should / can do to help extend the life of this drive as long as possible, without sacrificing performance by moving data to a traditional drive.
For example, of course defraging will be turned off on the drive. My download directory will be moved off to a traditional drive, especially for torrents.
Any suggestions?
My suggestion: Don't worry about it. By the time that thing starts failing.. you'll have much faster, higher capacity SSDs, at much better prices. Writing for 4hrs a day would give you decades of life...
My opinion: Don't buy an SSD yet.
Other than price, why wouldn't you want one of Intel's new SSDs?
The performance is just off the hook. I just did an install from my USB drive to the X25-M of Vista x64 (unattended other than to press enter to choose where to install it) in under 10 minutes.
That kind of performance is just insane.
I'm making my SSD OS drive trying to read only as much as possible.
Disabled Superfetch (i'm sure you could leave this on but haven't seen a benefit of doing so)
Changed Superfetch and prefetch off in registry (set keys to 0)
Disabled ReadyBoost (Don't need readyboot now since drive has low seek time)
Disabled Windows Search
Turned off Indexing on the drive and in programs
Disabled scheduled defrag
Moved PageFile to Raid 0 2x320gb array
Moved System Protection to Raid 0 array
Changed all enviroment variable TEMP directories to Raid 0 array
Redirect all downloads to other drives.
Install Games to Raid 0 array
Also use tweaks for firefox to move cache folder to Raid 0 array
Remember if you move the pagefile off the main drive, you need to delete it from the main drive, otherwise you just have about 3-4gbs wasted space.
So my Vista Home premium x64 will sit at around 11-12gbs and then add programs from there.
I think moving the page file off the SSD would hurt a lot of the performance gain from an SSD but maybe I don't know wtf I'm talking about. I have 12g of memory now so I doubt my page file is going to be hit that often anyways.
I think with some of the other suggestions i'll just try them and see if there is a performance hit. I want my shit tip top, that is why I have this crazy thing in the first place.
With and X-25 i'm sure there isn't a huge point for a performance impact, I moved mine off to a Raid setup about as fast as my MLC drive plus this has the advantage of not wearing the cells out as fast from swapping data in and out. You asked also about longevity + performance.
Basically anything with constant read/writes will lower drive life, but its not like the intels aren't rated at 50gb+/day for 5years life span
I think you guys are far too worried about the lifepsan of current SSDs (especially the Intel ones). It's not like ordinary harddrives can't get worn out and fail if they're bashed 24/7 by high I/O. Overall, if you dont fill your SSD up to the rim, it should outlast any mechanical harddrive by several factors. Afterall, there are no moving parts, and if anything, moving parts are keen to failure due to constant and repeated use.
$500, I'm going to be a little paranoid.
Also if a flash drive does fail it doen't become instaltly unreadable or dump all of the data it has on it . It only wont/cant be written to any longer because it is out of know good cells to put data on. So fo a os drive its is perfect, for a database serving data, not so much.
Hell the ony reason i'd ever run raid 0 is with 2 SSD drives if for the fact that the chance of failure is so much less than mechanical.
These drives are not the same a the flash in a digital camera that lacks wear leveling logic of drive controllers.
I think they aren't worth to money as compaired to a nice 640gb drive under $100, but if you need or want the speed there isn't much downside other than cost.
It's been shown by relatively simple math that even if you wrote 80GB of data per day (a 24 hour period) and then erased it and did it again in the next 24 hours, repeating ad nauseum, that you'd still be doing it over 80 years from now before you'd have something to even think about worrying about.
"What we have to fear... is stupid and not worth the worry in the first place..." to paraphrase a rather famous saying.
Do the tweaks the OCZ forums have listed in this subforum:
http://www.ocztechnologyforum.com/forum/forumdisplay.php?f=186
Read all the stickies, apply the knowledge (iirc Tony is a Microsoft employee, he posts a shitload of tips and tricks over there so... his stuff is solid in terms of usefulness), and be happy with the purchase.
You'll have gray hair before that thing has problems... and if you're using it even a year or two from now then... well... you'll figure it out. :)
with wear leveling (built into all SSDs these days) you don't have to worry about it.. A mechanical drive will fail from bearing seizure before your SSD will.
