x24800+Vapo
altre
Hi all,im new here and have some quastion:
im gonna buy x2 4800+Ballistix 2x1gb+ Vapo lightspeed
any1 knows wich Mhz for 24/7 usage i can get OC from this?
Regards
You know i was planning on doing the same thing.
Probably will get 3Ghz Per Core, 250FSB, you can run the ram at 1:1 and get 250MHz (DDR500) w/ Good timings and will be great.
YOu need voltage tho... so get a DFI Board...
so you saying i can get 3Mhz staible 24/7,with this
and yes im planning to get DFI SLI-DR
Another question about Vapo-does it only cooling CPU or other parths to?
only cpu. And you can probably get 3Ghz, not Mhz. 3Ghz = 1000mhz (if you didnt just make a typo).
However, due to the risks of this cooling (I've been doing it a while), If you are asking that question, I think maybe you should try air or watercooling first. With phase change you have to use insulation, grease, seal string, foam, etc, etc. You have to worry about condensation, getting a good mount, etc. It is fun, but there are a lot of hassels with it.
I suggest you do a little more research, head on over to xtremesystems.org/forums to see the best work on earth with phase change, and a great place to learn. That's where I learned everything I know about phase change.
Good luck.
it was typo,sry
and i dont wont wc or air
im not affraid to burn it to ,lol
thx for answer
