X2 & V-sync
Sphere
Hi Everyone,
I'm contemplating picking up the X2, but I've read conflicting posts that state v-sync can't be used on that card(crosfire/SLI) due to problems with AFR.
I run 90% of my games with it-I can't stand tearing, so it will be an essential function.
So, is this fact or fiction?
Thanks
Don't know about the X2 but I can use vsync just fine on my 4850 Crossfire setup, so I would assume the X2 would be the same.
Thanks Sabrewulf,
Since your using it on 4800 series in CF, then I'll presume it's fiction.
Thanks for the reply :)
Thanks Sabrewulf,
NP. If you have any specific scenarios in mind I can try to test them for you. I know vsync is working via console and fraps confirmation, I haven't done any real checking to see if it hurts CF performance a lot.
Sabrewulf,
Just wanted to make sure that using v-sync didn't cause any greater hit with AFR than on a single gpu.
I apply it on all my games-can't tolerate tearing of any degree.
Thanks
I played with 2 4850's in CF and had no problems using V-Sync. I am awaiting my 4870 X2.
