Hey fellas,
I just invested in a X2 3800+ and i have rather high temps. I have an Antec SLK3700 with a 480watt true power PSU. 2 x 120mm front and rear case fans with an Arctic Freezer 64 HSF and a 92mm fan cooling my ram down. At idle on my current OC (2.4ghz @ 1.4v) my temps are around 48C and load with 1 core around 54c and with both cores around 64c. I have remounted my HSF about 5 times and used different types of compound including arctic silver 2-3-5 and arctic silver ceramique and they all come up with the same result. I am wondering if the Arctic Freezer is not the best choice of heatsink for a dual core? Cheers
EDIT: I should also mention that even at stock vcore and speed temps are only like 2-3c cooler which is worrying. My old 3000+ never hit above 42-44C load on the same motherboard
