X2 6000+ using PC2-8500 speeds?
dyesan
Still running a 6000+ here on a Biostar TF7025-M2. I was wondering it there would be any advantage of having PC2-8500 ram with my X2. Current ratio of cpu is weird because my clock is 200mhz/15x multi but my DDR-800 ram is only running 375mhz. One option is to do slight overclock to 3.2 and run 16x multiplier (?) and run the ram at full speed, but I have spare Ballistix PC2-8500 lying around and was wondering if I could put it to good use here. I'd rather not overclock to avoid high temps (mATX box) so my question is can I keep 3.0ghz and use the Ballistix at DDR-1066 speeds?
