x2 3800 or x2 4600
Turkish621
Ok, So I plan on overclocking my chip that I buy, but I want to know if it will be worth spending the extra dough to get the faster MHZ to begin with. Or if they will both end up overclocking to about the same speeds. I know that no overclock is gauranteed, but I am just looking for any input.
With the price cuts the 4600 probably is a bit more attractive... but in the end they're gonna perform just about the same in everything except synthetics. Either one will hit between 2.4 (easy) and 3.0 (if yer lucky). The 3800 was a nice deal at $300, but it's a real bargain at $150. If the extra hundred for the 4600 is no big deal, go for it. But if you'd rather put the dough elsewhere, you'll be very pleased with the 3800...
3800 spend the money you would've spent on a 4600 on a kickass video card.
I went with the 4600 because I already know out of the box it'll run at 2.4GHz.
I could get the 3800 and feel pretty confident I could also get it to 2.4GHz, but after that it starts to become hit or miss. With my 4600, I am also confident I could push it close to 2.8GHz if not more. Really in the end you'll probably still have the same 400MHz difference in the chips. I was willing to pay $100 more for that. Especially since the 4800 is going alway and the FX-60 was way overpriced now.
To add... With games the difference between a 3800 and a 4600 is probalby not even going to be noticable, (though I hear with SLI it does start to become noticable). GPU is doing most of the work there. In applications that are CPU intensive, then you'll see the difference.
This interactive CPU chart is pretty handy.
http://www23.tomshardware.com/cpu.html
$100 is too much. $60 is supposed to be the difference and I was going to go with the 4600 then, but in the end I did not even do the 4200. Getting anything above the 3800 is less than a minute of encoding video and maybe 3 fps in a game...maybe. I spent the $100 saved on moving up to a X1900XT instead of a X1800XT.
thanks to all. I went with the 3800. Saved me some cash, and I hope that I get a good overclocker.
if you really think about it, it's just a numbers game. a lot of people buy into that crap. the only thing i ever notice is how the graphics look and how many frames I'm getting. :eek:
