Ok guys I finally reach the end of my testing and research. Alot of hours was put into this so I hope you guys enjoy it. Let this be a guide or reference to those who are curious as to what these chips can do. By far this little adventure was nothing short of amazing and a whole lot of WOW I'm pretty sure if I put a little more effort I might be able to hit 3.0, but we'll save that for the next adventure and when I get a better sticks. I will post screen shots upon request.
OC @ 2.6
Sandra Sisoft
CPU Arithmetic:
Dhrystone ALU - 21998
Whestone FPU/iSSE2 - 8242/10736
Memory Bandwidth:
Ram Bandwidth Int Buff'd iSSE2 - 6224
Ram Bandwidth Float Buff'd iSSE - 6184
EVEREST
Memory Read - 6592
Memory Write - 6735
Memory Copy - 5672
Memory Latency - 47.8
CPU Queen - 5003
CPU Photoworxx - 20622
CPU ZLib - 30429
FPU Julia - 2935
FPU Mandel - 4343
FPU SinJulia - 2704
OC 2.8ghz
Sandra Sisoft
CPU Arithmetic:
Dhrystone ALU - 23686
Whestone FPU/iSSE2 - 8879/11564
Memory Bandwidth:
Ram Bandwidth Int Buff'd iSSE2 - 5939
Ram Bandwidth Float Buff'd iSSE - 5944
EVEREST
Memory Read - 6131
Memory Write - 6227
Memory Copy - 5789
Memory Latency - 50.1
CPU Queen - 5386
CPU Photoworxx - 19844
CPU ZLib - 32967
FPU Julia - 3157
FPU Mandel - 4675
FPU SinJulia - 2912
BFG 7800GT OC @ Core 470 - Mem 1120
3DMark03 @ 2.6 - 15364
3DMark05 @ 2.6 - 7001
3DMark03 @ 2.8 - 17112
3DMark03 @ 2.8 - 8038
BIOS Settings @ 2.6
CPU Speed:
CPU Clock 2600.3 MHz (original: 2000 MHz, overclock: 30%)
CPU Multiplier 10.0x
CPU FSB 260.0 MHz (original: 200 MHz, overclock: 30%)
Memory Bus 216.7 MHz
DRAM:FSB Ratio CPU/12
Memory Timings:
CAS Latency (CL) 2T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 3T
RAS Active Time (tRAS) 6T
Row Cycle Time (tRC) 8T
Row Refresh Cycle Time (tRFC) 16T
Command Rate (CR) 1T
RAS To RAS Delay (tRRD) 2T
Write Recovery Time (tWR) 2T
Read To Write Delay (tRTW) 3T
Write To Read Delay (tWTR) 2T
Write CAS Latency (tWCL) 1T
Refresh Period (tREF) 200 MHz 15.6 us
DQS Skew Control Disabled
DRAM Drive Strength Weak
DRAM Data Drive Strength 1 (50% Reduction)
Max Async Latency 7 ns
Read Preamble Time 6.5 ns
Idle Cycle Limit 256
Dynamic Idle Cycle Counter Disabled
Read/Write Queue Bypass 16
Bypass Max 7
32-byte Granularity Disabled
Sensor Properties:
Sensor Type ITE IT8712F (ISA 290h)
GPU Sensor Type Diode (NV-Diode)
Motherboard Name DFI LANParty UT nF4 SLI-DR Expert
Chassis Intrusion Detected Yes
Temperatures:
CPU 29 °C (84 °F) - Load is about 38c
Chipset 50 °C (122 °F)
PWM 45 °C (113 °F)
GPU Diode 42 °C (108 °F)
Seagate ST380011A 34 °C (93 °F)
WDC WD400BB-00JKC0 41 °C (106 °F)
WDC WD3000JD-00KLB0 34 °C (93 °F)
Cooling Fans:
System 1974 RPM
Chipset 4327 RPM
Voltage Values:
CPU Core 1.33 V
+3.3 V 3.26 V
+5 V 4.92 V
+12 V 12.16 V
+5 V Standby 4.92 V
BIOS Settings @ 2.8
CPU Properties:
CPU Type DualCore AMD Athlon 64 X2
CPU Alias Manchester S939
CPU Stepping BH-E4
CPUID CPU Name AMD Athlon(tm) 64 X2 Dual Core Processor 3800+
CPUID Revision 00020FB1h
CPU Speed:
CPU Clock 2800.8 MHz (original: 2000 MHz, overclock: 40%)
CPU FSB 280.1 MHz (original: 200 MHz, overclock: 40%)
Memory Bus 200.1 MHz
DRAM:FSB Ratio CPU/14
Temperatures:
CPU 30°C (84 °F) - Load is about 38c
Chipset 47 °C (117 °F)
PWM 46 °C (115 °F)
GPU Diode 43 °C (109 °F)
Seagate ST380011A 32 °C (90 °F)
WDC WD400BB-00JKC0 39 °C (102 °F)
WDC WD3000JD-00KLB0 33 °C (91 °F)
Cooling Fans:
System 2096 RPM
Chipset 3924 RPM
Voltage Values:
CPU Core 1.39 V
+3.3 V 3.26 V
+5 V 4.92 V
+12 V 12.16 V
+5 V Standby 4.92 V
VBAT Battery 3.10 V
Memory Timings:
CAS Latency (CL) 2.5T
RAS Active Time (tRAS) 7T
DQS Skew Control Disabled DRAM Drive Strength Weak
Read Preamble Time 8.0 ns
Bypass Max 7
Disclaimer
Let this be a guide and reference, but by any means I guarantee these numbers and settings will reflect or work on a similar hardware. Final OC are tested with OCCT 30 min. test, Memtest Test No.5 40 pass No error, and 10hrs x2 prime95 In place large fft. All benchmarks are performed in my best abilities and knowledge.
This would not be possible with out these GREAT Guides:
http://www.hardforum.com/showthread.php?t=888001
http://www.dfi-street.com/forum/showthread.php?t=20823
OC @ 2.6
Sandra Sisoft
CPU Arithmetic:
Memory Bandwidth:
EVEREST
Memory Read - 6592
Memory Write - 6735
Memory Copy - 5672
CPU Queen - 5003
CPU ZLib - 30429
FPU Julia - 2935
FPU Mandel - 4343
FPU SinJulia - 2704
OC 2.8ghz
Sandra Sisoft
CPU Arithmetic:
Memory Bandwidth:
EVEREST
Memory Read - 6131
Memory Write - 6227
Memory Copy - 5789
CPU Queen - 5386
CPU ZLib - 32967
FPU Julia - 3157
FPU Mandel - 4675
FPU SinJulia - 2912
BIOS Settings @ 2.6
CPU Speed:
Memory Timings:
CAS Latency (CL) 2T
Bypass Max 7
Sensor Properties:
Temperatures:
PWM 45 °C (113 °F)
Cooling Fans:
System 1974 RPM
Chipset 4327 RPM
Voltage Values:
CPU Core 1.33 V
+3.3 V 3.26 V
+5 V 4.92 V
+12 V 12.16 V
+5 V Standby 4.92 V
BIOS Settings @ 2.8
CPU Properties:
CPU Stepping BH-E4
CPU Speed:
Temperatures:
PWM 46 °C (115 °F)
Cooling Fans:
System 2096 RPM
Chipset 3924 RPM
Voltage Values:
CPU Core 1.39 V
+3.3 V 3.26 V
+5 V 4.92 V
+12 V 12.16 V
+5 V Standby 4.92 V
VBAT Battery 3.10 V
Memory Timings:
Bypass Max 7
Disclaimer
