Hey,
both cards in the title are based on the same RV570 core. As far that I can see the only difference between the 2 cards are the freqs.
I've also seen that you can OC the x1950gt to x1950pro freqs pretty easily. My question is: If you OC the x1950pro will you get higher freqs that an OCed x1950gt? If so, why is that? same core, isn't it?
