snowysnowcones
- Apr 2, 2006
Don't think it's been posted yet. Sapphire X1950GT AGP: http://www.newegg.com/Product/Product.aspx?Item=N82E16814102093 $159.99
The GT is just more or less an X1950 Pro with slower clocks, correct? Are there any other differences? Haven't done much reading on the GT.
Thanks for posting this by the way. That really is an excellent price and would make a great card for an older AGP system or a casual gamer.
Is Newegg the only one that sells this thing? I want to buy one for folding, but $166.00 is a bit steep when the PCI-E version is $105AR.
Is this faster then the Pro???
Even with the added Pixel Pipelines? Not to mention you can probably overclock the GT, the Pro is stuck at stock speeds
It has the same pixel shaders as the Pro. Just lower clocks.
Stuck at "Stock Speeds"...?
Read my sig...
(I've had it higher but with stock cooling it overheats...)
PS:
As honestjohn has already mentioned, check out post #4
about "Actual" Pixel shaders... Newegg goofed...![]()
GT:
16(48 Pixel shader processor)
Pro:
12(36 Pixel shader processor)
It has the same what?
That's the nature of the AGP beast. We pay more.
If this thing was ~$110 it would make sense, but not $166. I might as well go C2D on my file server unless the PPD is adjusted for the GPU client. I wish the X1650 got more PPD.
AGP pricing never makes sense. Just look at the X1950 Pro AGP cards. Might as well go C2D becuase I don't think you'll ever see the X1950GT listed for $110 (new). The only AGP cards you'll find for that money are the 7300GT's, 7600GS's, X1550's, and a few X1650 Pro's. So if they charged $110 for the X1950GT, how much would those other cards go for? They would have to give them away.
How did you overclock? Seems like luck of the draw with these cards.
edit: Dang you newegg for mixing up the numbers!
