HI, I have a MicroATX case with and Antec 300W PS. I want to get a X1950 Pro. My CPU is a AMD 3000+ and 1GIG DDR ram, do you think I will need to upgrade my PS to run this card? I don't plan on overclocking anything. Thanks, John.
If your system is pcie you will have less power requirements because the card will be able to pull up to 75 watts from the motherboard. AGP can only pull less then 12 from the motherboard (and 3.3 volt line).
I have an Allied 500w psu with 22amps on the 12v and I can tell the x1950pro I just got is giving my psu hell.
[CaM]Spoon;1030716370 said:For your specs YOU DO NOT NEED MORE THEN 300watt.
Your using a micro motherbaord too which isnt power hungry and guessing from that you only have 1 harddrive and 1 cdrom? And your not overclocking.
Dont listen to these power hungry people. Your fine. Conserve your electricity and your wallet.
