Hello i was on a 9800XT and just recently upgraded my video card to a Sapphire x1950pro AGP 512mb and a Mushkin 550W power supply. Everything is installed correctly and the card is up and running but i have seen no real difference in FPS from my 9800XT. Not only that but my friend has a x800 and is running considerably better in terms of FPS. I play quite a bit of Battlefield 2 and run 1280X1024 75Hz and get only about 40 FPS and in some cases it will drop to about 15 FPS. . My friend runs the same settings and gets 60-80 FPS. Also when i switch to the lowest settings i only go up about 10-15 FPS. The FPS stays about the same no matter what resolution i change it to. My question is, What is the problem I am having? I'm led to believe that my CPU is not strong enough for the card.
My CPU is:
AMD Athlon 64 3400+
Sapphire X1950 Pro AGP 512 (7.1 drivers)
ASUS K8V SE Deluxe with the most recent Bios (1008.004)
Soundblaster Audigy 2 ZS
550w Mushkin Power Supply (20A on each 12v Rail)
2X Western Digital 120Gb IDE hard drives
Friends Computer:
Pentium 4 2.4 (O/C'd to 2.9)
x800 pro
400w Power Supply
2GB pc3500
My Scores:
Aquamark3: 51000
3Dmark06: 4061
Nothing is over-clocked, my monitor runs at 75Hz, V-sync is off, AA is application controlled, Anisotropic is Application controlled. Everything is at default
I tried OC the CPU but i have no video lock, so i was told that i should stop OCing.
If there is something i am missing let me know. Thank you and hopefully i can get some input.
My CPU is:
AMD Athlon 64 3400+
Friends Computer:
x800 pro
400w Power Supply
2GB pc3500
My Scores:
Aquamark3: 51000
3Dmark06: 4061
