was it not fixable when using "driver level overclocking" in ATT?
HardOCP said:It is important to note that when overclocking, the default overclocking method is low-level. This is the setting you will find on other applications such as Riva Tuner by default. However, with ATI cards, specifically low-end models overclocking the memory is a tricky ordeal. You cannot use low-level overclocking on the memory, it will simply not overclock, even by 1 MHz. Thankfully ATI Tray Tools lets you select driver level overclocking. In driver level mode the memory can be overclocked without problems.
