sabregen
- Jun 6, 2005
I am guessing that the concensus will be that I should uninstall board drivers, and video drivers, run Driver Cleaner, reboot, then re-install. That being said, here's the system specs:
abit kn9 SLI AM2
Brisbane 3600 @ 2993
OCZ Vista Upgrade 2x1GB kit (waiting for RMA on second kit
bbATI x1900xtx 512
XP Pro 32bit
latest nforce chipset drivers
latest CCC drivers
Seems that games do okay, although the previous owner topped all of my bench scores by about 10-20% across the board on a DFI LanParty 4 Ultra / opty 170 @ 2.8 / 2GB DDR1 combo, so I am a bit frustrated with the situation. I am using 3dmark06 scores because:
a.) this is the only score that he can really recall, since he hasn't used the card in months (duh...I've had it
b.) our system configs are pretty close, both nforce chipsets, same video card, similar CPU clocks, same amounts of RAM
Previous owners 3dmark06 scores = ~6200
My 3dMark06 scores = ~5200-5600
What is killing me is that his scores were consistantly around 6200 with this card, on his older AMD setup, and mine seem to be all over the place. I understand that the range is within the margin of error, but it is a larger fluctuation than I am used to seeing from my previously built rigs. Most of the time, I'm within 200 points between runs. And on top of that, I'm concerned about system performance not being where it should be.
Some of you will likely say:
"How do games run? Do you notice hiccups, stuttering? If the games run okay, forget about the 3dmark06 scores, they're useless anyways."
I will respond to that:
Games run fine, actually, which is what is so unnerving. I can run NFS Pro Street, Bioshock, and Crysis at 1920x1080 with a reasonable amount of options on, and FRAPS reports the FPS count hovering above 30 most of the time (which is fine, I mean...look at the sig specs...nothing fancy there). However, I've always been a person that likes excess. I have probably spent just as much time, if not more time benching my system, and tuning performance, as I have playing PC games over the course of my life. Yes, I know, it may be weird, but I cannot rest if something is known to be wrong with the machine, and it will drive me nuts. I can't just say "well, I don't know...I'm gonna play a game." I will walk away from a computer with an issue that I am having trouble with, before I will let the problem go, and move on to another activity. I can't play games if I tihnk the system isn't providing me the best performance that it can.
Anyways, any ideas other than Driver Cleaner and reloading the chipset/video drivers? I am at work now, and walked away from the machine last night to watch a movie with my fiancee, so the reload of drivers is my next step, but any other ideas are welcomed.
abit kn9 SLI AM2
bbATI x1900xtx 512
XP Pro 32bit
latest CCC drivers
