Diseaseboy
- Mar 27, 2001
ManicOne said:This is a stuff up. If you look properly it says X1900XTX Pro, while still claiming 48 shader units. A Pro would have disabled shaders (probable 32/36 effective) and no more than 256meg RAM. This is just an XTX, which the company thinks is a "professional" graphics card.
Unfortunately, we can no longer make those comparisons. I mean, the X850XTPE has a higher fillrate and memory bandwidth than the X1800XL and yet it gets stomped by the X1800XL in the vast majority of benchmarks. So it's obvious that the fillrate and bandwidth probably won't represent the actual performance of the X1900 series (also, taking into account that the R580 is using a new kind of un-specialized ALU architecture, the standard comparison using fillrate gets even more distorted).Nidhogg said:"Memory Bandwidth: 49.6 GB/sec"
"Pixel Fill Rate: 10.4 GP/sec"
thats almost exactly the same as the x1800XT, just a tiny bit higher.
GVX said:Looks like the only direct way we have to compare video cards now days is to look at gaming benchmarks.
