x1900xtx bracket replacement
im looking for single slot brackets for x1900 crossfire and x1900xtx cards...i will be watercooling these cards with the koolance blocks and require use of the adjacent pci slots on the intel badaxe board. anyone know where i can get em?
much appreciated!
You can always make one with a dremel, a spare case slot blockoff and some careful cutting.
Just remove the factory bracket, trace the pattern over the blankoff and get to cutting.
yikes, i dont know if i'm talented enough with a dremel for that kind of work? theres no where to buy a replacement bracket? i think its surprising koolance makes them for 7900 series but not x1900... :confused:
