Here are a few comparison performance numbers at 1680x1050, all medium settings for Crysis. I'm running Vista Business, 2GB RAM, P965 mobo, and a Yorkfield Q9550 CPU (stock).
Here's the X1900XT (stock speeds)
11/28/2007 6:04:25 PM - Vista
Beginning Run #1 on Map-island, Demo-benchmark_gpu
DX9 1680x1050, AA=No AA, Vsync=Disabled, 32 bit test, FullScreen
Demo Loops=3, Time Of Day= 9
Global Game Quality: Medium
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
!TimeDemo Run 0 Finished.
Play Time: 84.32s, Average FPS: 23.72
Min FPS: 16.15 at frame 1957, Max FPS: 32.41 at frame 995
Average Tri/Sec: 20555382, Tri/Frame: 866596
Recorded/Played Tris ratio: 1.06
!TimeDemo Run 1 Finished.
Play Time: 78.20s, Average FPS: 25.58
Min FPS: 16.15 at frame 1957, Max FPS: 38.44 at frame 79
Average Tri/Sec: 22390054, Tri/Frame: 875448
Recorded/Played Tris ratio: 1.05
!TimeDemo Run 2 Finished.
Play Time: 78.06s, Average FPS: 25.62
Average Tri/Sec: 22426450, Tri/Frame: 875268
TimeDemo Play Ended, (3 Runs Performed)
Completed All Tests
<><><><><><><><><><><><><>>--SUMMARY--<<><><><><><><><><><><><><>
Run #1- DX9 1680x1050 AA=No AA, 32 bit test, Quality: Medium ~~ Overall Average FPS: 25.6
And the freshly installed HD3870 (stock speeds):
11/28/2007 7:22:47 PM - Vista
Play Time: 53.19s, Average FPS: 37.60
Min FPS: 27.39 at frame 276, Max FPS: 55.25 at frame 894
Average Tri/Sec: 32591840, Tri/Frame: 866784
Play Time: 46.12s, Average FPS: 43.37
Min FPS: 27.39 at frame 276, Max FPS: 58.48 at frame 61
Average Tri/Sec: 37935368, Tri/Frame: 874772
Play Time: 45.50s, Average FPS: 43.96
Average Tri/Sec: 38473416, Tri/Frame: 875226
Completed All Tests
Run #1- DX9 1680x1050 AA=No AA, 32 bit test, Quality: Medium ~~ Overall Average FPS: 43.665
Hope this is helpful to anyone on the fence about a potential upgrade. I think I now enough overhead with the new card to increase the quality settings a bit in Crysis. I'm going to do some testing later with AA enabled.
Completed All Tests
Completed All Tests
