X1900XT Video In help needed
BinarySynapse
Ok, I'm trying to use the Video In feature of my MSI RX1900XT graphics card, but can't find anything specific enough to help me get it working. I don't need anything fancy, just simple viewing. I've tried Dscaler, VLC, AMCAP and none of them see my Video In. How do I get this working?
Forgot to mention that I'm using Vista Home Premium 32bit.
Well, I tried installing the XP driver for the AVStream device and it shows up as a source in VLC, but it still doesn't display the video from my cable box. Not even a black screen for that matter. Does anyone know how to get the VIVO functionality to work in Vista?
Don't know about vista, but on my XP system the way I get it to work with VLC is:
A) File > open capture device
B) under video device name, refresh list, select ATI T200 AV Stream
C) advanced options, check device properties, then OK
D) OK again, keep clicking OK until the windows that says crossbar on top comes up, and then select the appropriate video input. For some reason it always defaults to composite, so I have to change it to S-video in. Then click Ok again
E) That should hopefully do it.
Well, that helped some. Now I get a green screen in the VLC playback window. Step D I used the defaults since I'm using Composite input.
