I've had a Powercolor X1900XT card for less than a week. For some reason, it seems to be having problem retaining the refresh rate for my CRT, a Sony GDM-F520. My monitor is set to 1280x960 at 85 Hz. For the past two days, when I've turned on my computer after getting home, the monitor starts up at 120 Hz. Also, Windows no longer identifies the monitor as a Sony GDM-F520 but as "Default Monitor."
I can fix these problems by resetting the refresh rate to 85 Hz and by loading the ATI CCC (I set it up so that it doesn't automatically load on boot). When I load CCC, the program correctly identifies my monitor as a GDM-F520. Then, I restart and everything is fine; monitor remains at 85 Hz and Windows no longer says it's a default monitor but correctly identifies my monitor by its model name.
Although it's an easy fix, it's obviously not something I want to have to do everytime I start my computer. Powercolor is willing to swap out my card for a new one - and I can probably get Newegg to send me a new card without restocking fee because this card may be defective - but can anyone shed some light on my problem? Replacing my card is a hassle that I'd like to avoid if I can. Thanks for any suggestions.
