X1900XT in a Shuttle SN27P2????
bigshooter
Will I regret putting a big card in there? Is it too hot? I am deciding between a 7600GT, a 7900GT, and a X1900GT for ~$140, ~$240, and $299 respectively. THe X1900XT would give a huge bump in performance, but I don't want a card that will overheat in my little system.
Has anyone done this?
Thanks
You might want to wait for the X1950's, as they have they arctic cooling design for their heatsink.
the X1900XT will fit but as the user above stated, X1950 series is right around the corner so if you can wait, i suggest you do so but if you can't then go for the X1900XT.
I went for the X1900GT for $195.99 at the Egg... price/performance is what I was after.... what did you end up with?
X1950 will actually work out cheaper than the 1900xt series.
They want a lot sold before DX10 cards hit and it holds Nvidias' high end cards at bay.
