Justinkoko said:performance is neck to neck..
but thinking about power consumption... 7900 gt wins..
Actually, I would love a linkfallguy said:Sorry, the 7900GT does not equal the X1900XT.
Also, HQ AF, less shimmering, better AA, HDR+AA, is not "slightly better". I guess to someone who hasnt seen them in action... Need a link to [H]'s IQ comparisons?![]()
BlackTigers91 said:Actually, I would love a link.
When you look at all this added up it becomes clear that ATI still holds the image quality crown.
7900GT = X1900XT > X1900GT
To clarify:fallguy said:Sorry, the 7900GT does not equal the X1900XT..HDR+AA(!)
fallguy said:
fallguy said:And the fact is, you can do HDR+AA in some games, and NV currenlty cannot.
But good try?
Get a 7900GT KO Superclocked, it can be had for $260, it will whip the pants off an X1900GT, and it match the much more expensive X1900XT blow-for-blow.
I read your post. I was not denying this.fallguy said:If you actually read my post, it was seperated into two sections. The 7900GTis not as fast as the X1900XT, which is what he implied, and I refuted.
I was only attempting to "set the record straight" on the so-called HDR+AA support. Everyone here is absolutely terrible at this - you tell those who are faintly familiar with current video cards that the X1xxx series are the only cards that support any form of HDR and multisampling when this is simply not the case.fallguy said:But good try?
lloose said:those reviews are for the 7900gtX.. and the 7950.. we are talking about the 7900gt.
InorganicMatter said:Can the X1900GT do AA+HDR? Absoloutely, no one said it couldn't. Is it fast enough to do them at a decent resolution? Absoloutely not. People with dual X1900XTs struggle with HDR+AA in Olbivion. The fact that "it supports it" means nothing if it can't perform the function at a reasonable performance level in the real world.
fallguy said:^^ blah blah. Again, good try.
And? The IQ will be the same.
Way to follow the lead, and take only one aspect of the better IQ. As the [H] article shows, ATi clearly has the IQ advantage. HQ AF.. less shimmering.. etc.
And no, the KO cannot match the X1900XT. Especially if ran close to the same quality settings. Much more expensive X1900XT? Um, $30 or $40 is "much more"? Yet you dont mention the KO is "much more" expensive than the X1900GT? Nice.
Nvidia rules!itschop said:ATI baby!
^eMpTy^ said:Last I checked the X1900GT was selling for the exact same price as the 7900GT. The 7900GT is the clear performance winner (if you don't believe me, just read any review of the x1900gt), so unless you have a [H]ard|On for IQ or a desire to turn your computer into a space heater, the 7900GT is the card for you.
gostriker said:I like most people buy nice vid cards because I don't care about IQ.
biggles said:I have a 400 watt power supply, could this system (see sig for rest of specs) run either the 1800xt, 1900xt, 1900gt, or 7900gt? Or would it be safer to go with the 7900gt since it consumes less power? What is the power consumption on these cards like in relation to the 6800gt which would be swapped out?
The 1800xt is a better bang for the buck than the 7900gt, unless a new psu would be needed.
^eMpTy^ said:Fact is, most people can't tell the difference. If you can, then you have the option of getting the slower X1900 to get better image quality, but not everyone cares enough to sacrifice performance.
Not only is the X1900 GT a better performer in most cases than the stock 7900 GT,
gostriker said:Performance differences are generally quite marginal and besides performance is about slightly higher settings or IQ. From anands write up - seems the x1900gt wins in performance. And Hcop gives it the nod in IQ.
Link
So anyways not as clear cut as most like to say.
