x1900gt vs. 7900gs
pretty much the same, 7900gs might give you a bit better performance, but the 1900gt will have better image quality
They should be very similar... They trade blows at each other... Some games 7900gs is slightly faster... Some games 1900gt is a little faster...
lillimon04 said:
so should i get the x1900gt then? its onlu liek 150 and the 7900gs's r liek 170-200
That would be up to you... 7900gs does overclock a little better though but 1900gt has better image quality when you crank it up...
The new revision 2 x1900gt is just slower than a 7900gs overall, the old first revision was just faster according to Anandtech's holiday GPU buyers guide. The new ones have faster memory (1314 vs. 1200mhz.) I wonder if the 512mhz core overclocks well enough to match the older 575mhz core?
my x1300 pro will destroy you all! (kidding)
IMO i'd get the 7900GS .... better drivers, overclocking potential... 7900GS is basically a 7800GT anyway, and that's a damn fine card.
just my $0.02
well pillagenburn, is right and so is hawk, i do like nvidia drivers a bit better than stupid ati, i had big problems with catalyst controla month ago, i had to reformat my sytem and put a fresh windows on there. it was a good thing too cus my cod2 was messin up bad!!! and i love that game
Then install the driver-only package and use ATI Tray Tools as your control panel.
o shit not very smart with ati drivers, btu i thought u had to have catalyst control center, i i have alway rann both of them at the same time, is that gonna casue problems?
